Api session event editor panel export excel call tree
API Event to Export Excel Sheet Call Tree
| 0 | REQUIRED | (PANEL Integer ID) | Panel |
| 200 | byte[] (byte array) |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorpanel/export_excel_call_tree/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript Example POST:
body: '1'
fetch("https://development.tygron.com/api/session/event/editorpanel/export_excel_call_tree/", options)
