Api session event editor global set start value
API Event to Set Start Value
| 0 | REQUIRED | (GLOBAL Integer ID or multiple values in array [1, 2, 3]) | Global | |
| 1 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) | double[][] |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorglobal/set_start_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1.0, 2.0 ] ]'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorglobal/set_start_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ] ]'JavaScript Example POST:
body: '[ 1, [ 1.0, 2.0 ] ]'
fetch("https://development.tygron.com/api/session/event/editorglobal/set_start_value/", options)
