Api session event editor global set book value
Revision as of 06:51, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Book Value
0 REQUIRED (GLOBAL Integer ID) Global
1 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorglobal/set_book_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript Example POST:
 body: '[ 1, 1 ]'
fetch("https://development.tygron.com/api/session/event/editorglobal/set_book_value/", options)
