Api session event editor area add
Revision as of 06:48, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Add new Area
0 OPTIONAL (Integer number) Amount (optional)
200 Integer[] (Area IDs)
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorarea/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript Example POST:
 body: '1'
fetch("https://development.tygron.com/api/session/event/editorarea/add/", options)
