Api session event editor weather set trigger sec
API Event to Set whether the specified Weather's visualization Trigger automatically.
0 REQUIRED (WEATHER Integer ID) Weather ID
1 REQUIRED (Floating point number) Auto-Trigger (false means the Weather's visualization does not Trigger automatically)
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorweather/set_trigger_sec/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 65 ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorweather/set_trigger_sec/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 78 ]'
JavaScript Example POST:
 body: '[ 1, 65 ]'
fetch("https://development.tygron.com/api/session/event/editorweather/set_trigger_sec/", options)
