Api session event editor specialeffect add
API Event to Add new Special Effect
0 OPTIONAL (Point with crs: EPSG:3857) Location (optional)
1 OPTIONAL (PARTICLE_EMITTER Integer ID) Particle Emitter (optional)
200 Integer (Special Effect ID)
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorspecialeffect/add/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "", "" ]'
JavaScript Example POST:
 body: '[ "", "" ]'
fetch("https://development.tygron.com/api/session/event/editorspecialeffect/add/?crs=3857", options)
