Api session event editor parametric add
API Event to Add new Parametric
0 REQUIRED (Enumeration) Alignment ROAD or SPACED
200 Integer (Integer)
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorparametric/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"ROAD"'
JavaScript Example POST:
 body: '"ROAD"'
fetch("https://development.tygron.com/api/session/event/editorparametric/add/", options)
