Api session event editor panel set size
API Event to Set Size
0 REQUIRED (PANEL Integer ID) Panel
1 REQUIRED (Floating point number) Double
2 REQUIRED (Floating point number) Double
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorpanel/set_size/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 48, 85 ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorpanel/set_size/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 48, 93 ]'
JavaScript Example POST:
 body: '[ 1, 48, 85 ]'
fetch("https://development.tygron.com/api/session/event/editorpanel/set_size/", options)
