Api session event editor overlay set show system visualization
API Event to Set whether a specified Overlay visualizes the graph of systems which dictates its calculation. Pipes, center points of Area, etc.
0 REQUIRED (OVERLAY Integer ID) Overlay ID (must relate to a water Overlay)
1 REQUIRED (Enumeration) Visual Type AREAS or OBJECTS
2 REQUIRED (true, false) Show true or false
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editoroverlay/set_show_system_visualization/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "OBJECTS", true ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editoroverlay/set_show_system_visualization/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "OBJECTS", false ]'
JavaScript Example POST:
 body: '[ 1, "OBJECTS", true ]'
fetch("https://development.tygron.com/api/session/event/editoroverlay/set_show_system_visualization/", options)
