Api session event editor netload set node
API Event to Set Node
0 REQUIRED (NET_LOAD Integer ID) Net Load
1 REQUIRED (NET_NODE Integer ID) Net Node
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editornetload/set_node/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript Example POST:
 body: '[ 1, 1 ]'
fetch("https://development.tygron.com/api/session/event/editornetload/set_node/", options)
