Api session event editor netload add
API Event to Add new Net Load
0 REQUIRED (Enumeration) Net Type ELECTRICITY, GAS, HEAT, INTERNET or SEWER
1 REQUIRED (true, false) Is root load true or false
200 Integer (Net Load ID)
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editornetload/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "ELECTRICITY", false ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editornetload/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "ELECTRICITY", true ]'
JavaScript Example POST:
 body: '[ "ELECTRICITY", false ]'
fetch("https://development.tygron.com/api/session/event/editornetload/add/", options)
