Api session event editor netline add
API Event to Add a Net Line with the provided Net Function
| 0 | REQUIRED | (NET_FUNCTION Integer ID) | Net Function ID |
| 200 | Integer (Net Line ID) |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editornetline/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript Example POST:
body: '1'
fetch("https://development.tygron.com/api/session/event/editornetline/add/", options)
