Api session event editor indicator set excel
API Event to Set Excel Sheet
0 REQUIRED (INDICATOR Integer ID) Indicator
1 REQUIRED (EXCEL_SHEET Integer ID) Excel Sheet
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorindicator/set_excel/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript Example POST:
 body: '[ 1, 1 ]'
fetch("https://development.tygron.com/api/session/event/editorindicator/set_excel/", options)
