Api session event editor area generate inundation areas
API Event to Generate Inundation Area
0 REQUIRED (Floating point number) Double
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorarea/generate_inundation_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '78'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorarea/generate_inundation_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '42'
JavaScript Example POST:
 body: '78'
fetch("https://development.tygron.com/api/session/event/editorarea/generate_inundation_areas/", options)
