Api session event editor area add relation
API Event to Add Relation
0 REQUIRED (AREA Integer ID) Area
1 REQUIRED (Enumeration) Relation BORDER_A, BORDER_B, BUILDING, CONSTRUCTOR, DEMOLISHER, NETOWNER, OWNER, PARENT, PERMITTER, RECEIVER, RESULT_PARENT, SENDER or WEATHER
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorarea/add_relation/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "OWNER" ]'
JavaScript Example POST:
 body: '[ 1, "OWNER" ]'
fetch("https://development.tygron.com/api/session/event/editorarea/add_relation/", options)
