Api session event editor weather set trigger sec
Revision as of 12:15, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set whether the specified Weather's visualization Trigger automatically.
0 REQUIRED (WEATHER Integer ID) Weather ID
1 REQUIRED (Floating point number) Auto-Trigger (false means the Weather's visualization does not Trigger automatically)
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorweather/set_trigger_sec/?f=JSON&token=API_TOKEN
with content:
[ 68, 60 ]
