Api session event editor specialeffect remove particle pair
Revision as of 12:14, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Remove Particle Pair
0 REQUIRED (SPECIAL_EFFECT Integer ID or multiple values in array [1, 2, 3]) Special Effect
1 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Integer[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorspecialeffect/remove_particle_pair/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]
