Api session event editor parametric add
Revision as of 12:10, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Add new Parametric
0 REQUIRED (Enumeration) Alignment ROAD or SPACED
200 Integer (Integer)
Example POST: https://engine.tygron.com/api/session/event/editorparametric/add/?f=JSON&token=API_TOKEN
with content:
[ "SPACED" ]
