Api session event editor panel set url
Revision as of 12:10, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Url
0 REQUIRED (PANEL Integer ID) Panel
1 REQUIRED (String) String
200 String (String)
Example POST: https://engine.tygron.com/api/session/event/editorpanel/set_url/?f=JSON&token=API_TOKEN
with content:
[ 9, "Text" ]
