Api session event editor panel set template relation
Revision as of 12:10, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Template Relation
0 REQUIRED (PANEL Integer ID) Panel
1 OPTIONAL (Enumeration) Relation
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorpanel/set_template_relation/?f=JSON&token=API_TOKEN
with content:
[ 46, "" ]
