Api session event editor panel set template attribute
Revision as of 12:10, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Template Attribute
0 REQUIRED (PANEL Integer ID) Panel
1 REQUIRED (String) String
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorpanel/set_template_attribute/?f=JSON&token=API_TOKEN
with content:
[ 84, "Text" ]
