Api session event editor panel set template apply automatically
Revision as of 12:10, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Template Apply Automatically
0 REQUIRED (PANEL Integer ID or multiple values in array [1, 2, 3]) Template Panel
1 REQUIRED (true, false) Apply automatically at start of session true or false
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorpanel/set_template_apply_automatically/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], true ]
