Api session event editor overlay set show system visualization
Revision as of 12:10, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set whether a specified Overlay visualizes the graph of systems which dictates its calculation. Pipes, center points of Area, etc.
0 REQUIRED (OVERLAY Integer ID) Overlay ID (must relate to a water Overlay)
1 REQUIRED (Enumeration) Visual Type AREAS or OBJECTS
2 REQUIRED (true, false) Show true or false
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editoroverlay/set_show_system_visualization/?f=JSON&token=API_TOKEN
with content:
[ 26, "OBJECTS", true ]
