Api session event editor netline set net function
Revision as of 12:09, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set the Net Function for a Net Line
0 REQUIRED (NET_LINE Integer ID or multiple values in array [1, 2, 3]) Net Line
1 REQUIRED (NET_FUNCTION Integer ID or multiple values in array [1, 2, 3]) Net Function
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editornetline/set_net_function/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]
