Api session event editor netline insert point
Revision as of 12:09, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Insert a new Node in an existing Net Line, potentially splitting the Net Line into two parts. Also specify at what distance the new Nodes are merged with existing Nodes.
0 REQUIRED (NET_LINE Integer ID) Net Line ID
1 REQUIRED (Point 3D with crs: EPSG:3857) Inserted Node Point
2 OPTIONAL (Floating point number) Node merge distance (optional, default: 1.0m)
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editornetline/insert_point/?crs=3857&f=JSON&token=API_TOKEN
with content:
[ 22, {
 "type" : "Point",
 "coordinates" : [ 658777.366561448, 6799318.4767650375, -0.19 ]
}, 1.0 ]
