Api session event editor measure add terrain polygons
Revision as of 12:07, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Add polygons to existing outer (or inner) polygons of a Terrain Spatial of a Measure.
0 REQUIRED (MEASURE Integer ID) Measure ID
1 REQUIRED (Integer number) Terrain Spatial ID
2 REQUIRED (true, false) Is Outer (false = inner) true or false
3 REQUIRED (MultiPolygon with crs: EPSG:3857) MultiPolygon
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editormeasure/add_terrain_polygons/?crs=3857&f=JSON&token=API_TOKEN
with content:
[ 77, 50, true, {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799405.777876438 ], [ 658669.517428272, 6799405.777876438 ], [ 658669.517428272, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
