Api session event editor indicator set excel
Revision as of 12:07, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Excel Sheet
0 REQUIRED (INDICATOR Integer ID) Indicator
1 REQUIRED (EXCEL_SHEET Integer ID) Excel Sheet
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorindicator/set_excel/?f=JSON&token=API_TOKEN
with content:
[ 35, 86 ]
