Api session event editor indicator export debug excel
Revision as of 12:07, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Export Debug Excel Sheet
0 REQUIRED (INDICATOR Integer ID) Indicator
200 byte[] (byte array)
Example POST: https://engine.tygron.com/api/session/event/editorindicator/export_debug_excel/?f=JSON&token=API_TOKEN
with content:
[ 27 ]
