Api session event editor global set query timing
Revision as of 12:06, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Query Timing
0 REQUIRED (GLOBAL Integer ID or multiple values in array [1, 2, 3]) Global
1 REQUIRED (Timing or multiple values in array [a, b, c]) Timing[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorglobal/set_query_timing/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ "AFTER", "BEFORE", "BEFORE" ] ]
