Api session event editor geotiff add
Revision as of 12:06, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Add new GeoTIFF Item with provided file. For files larger than 2GB, use the Stream API or Web URL.
0 REQUIRED (String) GeoTIFF Name
1 REQUIRED (byte or multiple values in array [a, b, c]) File bytes (< 2GB)
2 REQUIRED (String) Uploader
3 OPTIONAL (String) CRS Override (optional)
200 Integer (GeoTIFF ID)
Example POST: https://engine.tygron.com/api/session/event/editorgeotiff/add/?f=JSON&token=API_TOKEN
with content:
[ "GeoTIFF Name", [ 1, 2, 3 ], "Uploader", "" ]
