Api session event editor geoplugin set layer name
Revision as of 12:06, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Layer Name
0 REQUIRED (GEO_PLUGIN Integer ID or multiple values in array [1, 2, 3]) Geo Plugin
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) String[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorgeoplugin/set_layer_name/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ "Text 1", "Text 2", "Text 3" ] ]
