Api session event editor geoplugin add new links
Revision as of 12:06, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Add New Links
0 REQUIRED (GEO_PLUGIN Integer ID or multiple values in array [1, 2, 3]) Geo Plugin
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) String[]
200 Integer[] (Integer array)
Example POST: https://engine.tygron.com/api/session/event/editorgeoplugin/add_new_links/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ "Text 1", "Text 2", "Text 3" ] ]
