Api session event editor area add relation
Revision as of 12:04, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Add Relation
0 REQUIRED (AREA Integer ID) Area
1 REQUIRED (Enumeration) Relation BORDER_A, BORDER_B, BUILDING, CONSTRUCTOR, DEMOLISHER, NETOWNER, OWNER, PARENT, PERMITTER, RECEIVER, RESULT_PARENT, SENDER or WEATHER
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorarea/add_relation/?f=JSON&token=API_TOKEN
with content:
[ 2, "RESULT_PARENT" ]
