Api session event editor address set point
Revision as of 12:03, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set the point of an Address
0 REQUIRED (ADDRESSE Integer ID or multiple values in array [1, 2, 3]) Address ID
1 REQUIRED (Point with crs: EPSG:3857 or multiple values in array [a, b, c]) Point
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editoraddress/set_point/?crs=3857&f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ {
 "type" : "Point",
 "coordinates" : [ 658673.998419755, 6799376.353660304 ]
 "type" : "Point",
 "coordinates" : [ 658797.252483781, 6799432.798486393 ]
 "type" : "Point",
 "coordinates" : [ 658673.0288105069, 6799328.656676102 ]
