Api session event editor address add
Revision as of 12:03, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Building Address belong to
0 REQUIRED (BUILDING Integer ID or multiple values in array [1, 2, 3]) Building
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Street name
200 Integer[] (Integer array)
Example POST: https://engine.tygron.com/api/session/event/editoraddress/add/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ "Street name 1", "Street name 2", "Street name 3" ] ]
