Api session event editor building generate water connection
API Event to Generate Water Connection.
0 REQUIRED (FUNCTION Integer ID) Function
1 REQUIRED (MultiPolygon with crs: EPSG:3857) Area
2 REQUIRED (Floating point number) Min Length
3 REQUIRED (Floating point number) Max Length
4 REQUIRED (Floating point number) Width
5 REQUIRED (Floating point number) Large Road Area
6 REQUIRED (Floating point number) Straight Distance
7 REQUIRED (Floating point number) Max Height Difference
8 REQUIRED (Floating point number) Ignore Upstream
9 REQUIRED (true, false) Include Water Bodies true or false
200 Integer (Amount of generated Objects)
Example POST: https://engine.tygron.com/api/session/event/editorbuilding/generate_water_connection/?crs=3857&f=JSON&token=API_TOKEN
with content:
[ 55, {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799436.066237129 ], [ 658668.2603469354, 6799436.066237129 ], [ 658668.2603469354, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
}, 73, 31, 74, 68, 67, 35, 10, true ]
