Api session event editor specialeffect set active
API Event to Set Special Effect active
0 REQUIRED (SPECIAL_EFFECT Integer ID or multiple values in array [1, 2, 3]) Special Effect
1 REQUIRED (Boolean or multiple values in array [true, false, true]) Boolean[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorspecialeffect/set_active/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ true, false, true ] ]
