Api session event editor netload generate loads and paths
API Event to Generate Loads And Paths
0 REQUIRED (NET_FUNCTION Integer ID) Net Function
1 REQUIRED (MultiPolygon with crs: EPSG:3857) MultiPolygon
2 REQUIRED (Category or multiple values in array [a, b, c]) Category[]
3 REQUIRED (Integer number) Integer
4 REQUIRED (Integer number) Integer
5 REQUIRED (STAKEHOLDER Integer ID or multiple values in array [1, 2, 3]) Stakeholder
6 REQUIRED (STAKEHOLDER Integer ID or multiple values in array [1, 2, 3]) Stakeholder
7 REQUIRED (true, false) Boolean true or false
8 REQUIRED (Floating point number) Double
9 REQUIRED (Floating point number) Double
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editornetload/generate_loads_and_paths/?crs=3857&f=JSON&token=API_TOKEN
with content:
[ 40, {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799327.07316963 ], [ 658732.4348364116, 6799327.07316963 ], [ 658732.4348364116, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
}, [ "HEALTHCARE", "LUXE", "ROAD" ], 3, 37, [ 1, 2, 3 ], [ 1, 2, 3 ], true, 81, 14 ]
