Api session event editor netline remove repeated
API Event to Remove the Net Line, and optionally continue removing for Net Node that are connected the removed Net Line and that are only connected to one other Net Line of the same Net Type of the specified Net Line.
| 0 | REQUIRED | (NET_LINE Integer ID or multiple values in array [1, 2, 3]) | Net Line IDs | |
| 1 | REQUIRED | (true, false) | Is repeated removal | true or false |
| 204 | No Content |
Example POST: https://engine.tygron.com/api/session/event/editornetline/remove_repeated/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], false ]
