Api session event editor panel edit answer event
API Event to Edit Answer (Panel) Event
| 0 | REQUIRED | (PANEL Integer ID) | Panel | |
| 1 | REQUIRED | (Integer number) | Integer | |
| 2 | REQUIRED | (true, false) | Boolean | true or false |
| 3 | REQUIRED | (CodedEvent) | CodedEvent |
| 204 | No Content |
Example POST: https://engine.tygron.com/api/session/event/editorpanel/edit_answer_event/?f=JSON&token=API_TOKEN
with content:
[ 48, 52, false, {
"id" : -1,
"parameters" : [ ]
