Api session event editor overlay set show system visualization
API Event to Set whether a specified Overlay visualizes the graph of systems which dictates its calculation. Pipes, center points of Area, etc.
| 0 | REQUIRED | (OVERLAY Integer ID) | Overlay ID (must relate to a water Overlay) | |
| 1 | REQUIRED | (Enumeration) | Visual Type | AREAS or OBJECTS |
| 2 | REQUIRED | (true, false) | Show | true or false |
| 204 | No Content |
Example POST: https://engine.tygron.com/api/session/event/editoroverlay/set_show_system_visualization/?f=JSON&token=API_TOKEN
with content:
[ 39, "AREAS", true ]
