Api session event editor measure import terrains
API Event to Import Measure Terrain Collection
0 REQUIRED (GeometryCollection with crs: EPSG:3857) Collection of Terrain Geometries
1 REQUIRED (Enumeration) Measure Edit Type BUILDING, FLATTEN, GEOTIFF, GRID, LEVEE, RAISE, UPGRADE or WATER
2 REQUIRED (Boolean or multiple values in array [true, false, true]) Is Inner
3 REQUIRED (TERRAIN_TYPE Integer ID or multiple values in array [1, 2, 3]) Terrain Type IDs
4 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Override Inner Height sector
5 REQUIRED (Boolean or multiple values in array [true, false, true]) Height Relative
6 OPTIONAL (MEASURE Integer ID) Set for existing Measure ID (optional)
7 OPTIONAL (Floating point number) Buffer for Points and Lines to make Polygons (optional)
8 OPTIONAL (SOURCE Integer ID) Source (optional)
200 Integer (Measure ID)
Example POST: https://engine.tygron.com/api/session/event/editormeasure/import_terrains/?crs=3857&f=JSON&token=API_TOKEN
with content:
 "type" : "GeometryCollection",
 "geometries" : [ {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799393.959128652 ], [ 658645.3307935625, 6799393.959128652 ], [ 658645.3307935625, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799398.095769618 ], [ 658685.9033373229, 6799398.095769618 ], [ 658685.9033373229, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799306.956980034 ], [ 658762.0087305445, 6799306.956980034 ], [ 658762.0087305445, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
}, "GRID", [ true, false, true ], [ 1, 2, 3 ], [ 1.0, 2.0, 3.0 ], [ true, false, true ], "", "", "" ]
