Api session event editor indicator set parent
API Event to Set a parent Indicator for a specified Indicator. This will cause the specified Indicator to be a subselectable Indicator of the parent. It is not possible to set an Indicator which has a parent itself as a parent of another Indicator.
| 0 | REQUIRED | (INDICATOR Integer ID) | Indicator ID | |
| 1 | REQUIRED | (Integer number) | Indicator ID of parent (Indicator without a parent should have their parent Indicator ID set to -1) |
| 204 | No Content |
Example POST: https://engine.tygron.com/api/session/event/editorindicator/set_parent/?f=JSON&token=API_TOKEN
with content:
[ 59, 83 ]
