Api session event editor building generate water connection
API Event to Generate Water Connection.
| 0 | REQUIRED | (FUNCTION Integer ID) | Function | |
| 1 | REQUIRED | (MultiPolygon with crs: EPSG:3857) | Area | |
| 2 | REQUIRED | (Floating point number) | Min Length | |
| 3 | REQUIRED | (Floating point number) | Max Length | |
| 4 | REQUIRED | (Floating point number) | Width | |
| 5 | REQUIRED | (Floating point number) | Large Road Area | |
| 6 | REQUIRED | (Floating point number) | Straight Distance | |
| 7 | REQUIRED | (Floating point number) | Max Height Difference | |
| 8 | REQUIRED | (Floating point number) | Ignore Upstream | |
| 9 | REQUIRED | (true, false) | Include Water Bodies | true or false |
| 200 | Integer (Amount of generated Objects) |
Example POST: https://engine.tygron.com/api/session/event/editorbuilding/generate_water_connection/?crs=3857&f=JSON&token=API_TOKEN
with content:
[ 54, {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799406.063722415 ], [ 658732.4624467252, 6799406.063722415 ], [ 658732.4624467252, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
}, 46, 66, 23, 38, 29, 31, 28, false ]
