Api session event editor panel set template use owner
Revision as of 07:54, 31 March 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Template Use Owner
0 REQUIRED (PANEL Integer ID) Panel
1 REQUIRED (true, false) Boolean true or false
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorpanel/set_template_use_owner/?f=HTML&token=API_TOKEN
with content:
[ 61, false ]
