Api session event editor building generate water connection
Revision as of 13:44, 30 March 2026 by Frank@tygron.nl (talk | contribs)
API Event to Generate Water Connection.
0 REQUIRED (FUNCTION Integer ID) Function
1 REQUIRED (MultiPolygon with crs: EPSG:3857) Area
2 REQUIRED (Floating point number) Min Length
3 REQUIRED (Floating point number) Max Length
4 REQUIRED (Floating point number) Width
5 REQUIRED (Floating point number) Large Road Area
6 REQUIRED (Floating point number) Straight Distance
7 REQUIRED (Floating point number) Max Height Difference
8 REQUIRED (Floating point number) Ignore Upstream
9 REQUIRED (true, false) Include Water Bodies true or false
200 Integer (Amount of generated Objects)
Example POST: https://engine.tygron.com/api/session/event/editorbuilding/generate_water_connection/?crs=3857&f=HTML&token=API_TOKEN
with content:
[ 12, {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 657384.7571861652, 6801356.7198541 ], [ 657384.7571861652, 6801298.502270633 ], [ 657517.4817974309, 6801298.502270633 ], [ 657517.4817974309, 6801356.7198541 ], [ 657384.7571861652, 6801356.7198541 ] ] ] ]
}, 80, 66, 35, 66, 4, 21, 24, true ]
