Api session event editor panel edit answer event
Revision as of 12:23, 30 March 2026 by Frank@tygron.nl (talk | contribs)
API Event to Edit [[Answer (Panel)]] Event
0 REQUIRED (PANEL Integer ID) Panels
1 REQUIRED (Integer number) Integer
2 REQUIRED (true, false) Boolean true or false
3 REQUIRED (CodedEvent) CodedEvent
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorpanel/edit_answer_event/?f=HTML&token=API_TOKEN
with content:
[ 50, 12, false, {
 "id" : -1,
 "parameters" : [ ]
