Api session event editor weather set trigger sec
Revision as of 10:27, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set whether the specified weather's visualization triggers automatically. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(WEATHER Integer ID) |Weather ID | |- |1 |REQUIRED |(Floating point number) |Auto-trigger (false means the weather's visualization does not trigger automatically) | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST==...")
0 REQUIRED (WEATHER Integer ID) Weather ID
1 REQUIRED (Floating point number) Auto-trigger (false means the weather's visualization does not trigger automatically)
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorweather/set_trigger_sec/?f=HTML&token=API_TOKEN
with content:
[ 90, 58 ]
