Api session event editor setting set limit map
Revision as of 10:23, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Project Map Limit Area {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(MultiPolygon with crs: EPSG:3857) |Limit Polygon | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorsetting/set_limit_map/?crs=3857&f=HTML&token=API_TOKEN with content: <pre>[ { "type" : "Mul...")
0 REQUIRED (MultiPolygon with crs: EPSG:3857) Limit Polygon
204 No Content
with content:
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799461.813625413 ], [ 658778.3150569267, 6799461.813625413 ], [ 658778.3150569267, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
