Api session event editor setting set export crs
Revision as of 10:23, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Export Crs {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(String) |String | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorsetting/set_export_crs/?f=HTML&token=API_TOKEN with content: <pre>[ "Text" ] </pre> {{article end|seealso=*api session event editor setting...")
0 REQUIRED (String) String
204 No Content
with content:
[ "Text" ]
